ivandurago
- Jun 5, 2008
This is a build my friend wanted advice on before he ordered.
It will be an entertainment PC/ web browsing/ school work and gaming. He is a biology major so not sure if that would cause him to use specialty apps.
He plays games on both his TV and PC monitor, not 100% on the size, so lets say at/under 1080p for both.
He basically wants as fast a PC as he can get for his budget, with at least a 1.5 TB hard drive, and future proofing as much as possible.
Entertainment PC/Gaming/School work/ect
~$800-1000 w/ shipping
3) Where do you live?
Wyoming
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU/MOBO/RAM/VID/PSU/Case/Key and mouse/ DVD drive
Maybe a couple old hard drives or cd drives...
6) Will you be overclocking?
He may in the future, not the most important item.
A TV and Monitor, both around 1080p
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license?
He will be purchasing the student $30 Win 7 license.
Here is what I initially put together for him (but obvioulsy will change anything on advice, especially Danny Bui's and enginurd's
AMD Phenom II x4 955 | ASUS EVO 790X | G.Skill Ripjaw 4gb - $343
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.308218
XFX 5750 1GB - $139
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150448
Western Digital Caviar Green 1.5TB - $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136351
Corsair 400CX - $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
LG Black DVD R/W - $28
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136168
Antec 300 - $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Keyboard/Mouse - $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16823204012
~$785 + $30 for Win7 = ~$815
edit: (here is a statement from him)
Wyoming
ASAP
N/A
XFX 5750 1GB - $139
Corsair 400CX - $50
Antec 300 - $55
I may be gaming a little on it, I realized I could play Left for Dead on it but prob not a lot past that, I have a PS3. I think besides just a comp for school, I was looking at it being a more of entertainment system. I'll be downloading movies and music for it and be using it to replace ever having to get cable by using streaming video. Do you have any suggestions for that purpose? I'd be willing to spend more on a video card if necessary, I have no idea what to go for on a card and was going off prices and newegg ratings. It will be hooked up to 19" monitor w/ DVI and a 1080i 37" w/ HDMI and my audio receiver. I'm not entirely sold on anything I've picked out so far so if you have more suggestions for a build. I liked the Antec case because it was cheaper, and had pretty good air flow, the lights aren't necessary but looked pretty good. I was also thinking about a HTPC case but I was wondering if they overheat and they seem more expensive than midtowers with the same features. Also I need a lot of help in finding out what power supply I should be running to allow some hard drive expansion in the future or may be another video card. Do you advise having 2 hard drives to run Ubuntu and Micro 7 or partition the 1.5 TB, or just stick with 7. I think I'd be willing to bump the cost up to around $1000-$1100 if there is some good investments. Thanks again.
