$850 Build
m_cochran
modded skyrim, elderscrolls online, and virtualbox running Backbox, Win XP, and another Linux
$850.00 all in.
Lake Dallas, TX - work 5 minutes from a Fry's
Microcenter about 45 minutes away. I also have a Prime membership with Amazon if it matters.
CPU/Motherboard
RAM
Dual Monitors 23-24"
GPU
SSD (if possible)
Power Supply
Case: Cooler Master Elite 430 (3 Fans, Front, Back, Bottom)
HD: Samsung 500GB F3
OS: Windows 7 HP 64-Bit
6) Will you be overclocking?
If need be
Need new dual 23-24"
2-3 weeks at most
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing comes to mind
Yes, Windows 7 HP 64-bit
This is my current system I am upgrading from... I am having a trouble running Skyrim modded smoothly. Everything else it does perfectly.
Case: Cooler Master Elite 430 - Motherboard: BioStar A880G+ - CPU: Phenom II X4 B50, OC'ed to 3.56GHz - RAM: 8GB DDR3 1333 - HD: Samsung 500GB F3 - Video: XFX Radeon HD 6850 - OS: Windows 7 HP 64-Bit
I think you're going to have up your budget a little:
$186 - Intel Core i5-4430 CPU
$83 - AsRock H87M Pro4 Intel H87 mATX Motherboard
$70 - Kingston HyperX Blu KHX1600C10D3B1/8G 8GB DDR3 1600 RAM
$240 - MSI N760-2GD5/OC GeForce GTX 760 2GB Video Card
$70 - Antec NEO ECO 620C 620W PSU
$260 - 2 x HP Smartbuy LV2311 Black 23" LCD Monitor
Total: $909 shipped.
+1 on the ssd
I'd also invest in more ram, personally I'm outgrowing 32gb running VMware workstation with 3 guests on their own ssd.
I can up to $950 maybe $1000 if it is really worth it.
Yes totally worth going to $1000 since that means you can get a SSD:
$89 - Samsung 840 Evo 120GB SSD
What do you think about this card?
Sapphire Radeon R9 270X 4GB
If it was by Asus, MSI, or GIgabyte, it would not be a bad card since the R9 270X isn't all that much slower than the GTX 760. But since it's from Sapphire, I can't recommend it unless you are absolutely planning on getting a monitor with at least a 2560x1440 resolution right now. Not to mention that it's not that much cheaper than the GTX 760 I posted. So not a good buy at all.
Also, looking at this case as I am giving mine to my son.
Corsair Obsidian Series 350D
Not a fan of the price but the case is good.
Don't plan on that, I can't bring myself to spend 300 - 400 per monitor for that resolution. If they ever came down to the sub 300 range maybe.
Ordering Monday...
Open to any suggestions. $950 is the max I can squeeze my budget to, so no SSD at this time. Most likely will pick up an SSD and another 8GB of RAM in a month or so.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($179.99 @ Amazon)
Motherboard: ASRock B75M R2.0 Micro ATX LGA1155 Motherboard ($64.49 @ Amazon)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory ($63.99 @ Amazon)
Video Card: MSI GeForce GTX 760 2GB Video Card ($239.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case ($59.99 @ Amazon)
Power Supply: Corsair Gaming 600W 80+ Bronze Certified ATX Power Supply ($69.99 @ Amazon)
Monitor: Acer G236HLBbd 60Hz 23.0" Monitor ($128.57 @ Amazon)
Total: $935.58
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-06 21:53 EST-0500)
Go with the Corsair 230T since it has better cooling than the Corsair 200R:
$60 - Corsair Graphite Series 230T Greyw/ Window ATX Case
I'd go with this more reputable Biostar B75 mobo for $3 more (and has two more RAM slots):
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138357
As for the PSU, I still recommend the Antec I recommended earlier since it's of higher quality than the Corsair.
What makes the 230T better at cooling? The 200R has more fan mounts than the 230T. I can pick up a couple of extra fans if that is all it is. I like the way it looks a lot more than the 230T.
It's an ok motherboard. But if you're going to spend that much, you might as well go for the Haswell setup I recommended earlier. The IB setup only makes sense if it's significantly cheaper than Haswell.
A couple of things about that Fractal Case. The motherboard tray cut out is to high on some motherboards which can be a problem when installing a cooler similar to a CM Hyper 212+, MB tray actually pushes on the cooler backing plate and two of the nuts are difficult to tighten if the MB is already installed. If you want to put a bottom intake fan in the floor of case you need to install the PSU first. Otherwise it's not a bad case, plenty of room behind the MB tray for cable management, removable center drive cage, adequate airflow.
Also, what do you think of this case... I found one for sale on Craigslist for $40
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352008
The 230t has a more open mesh front which allows for more air to come through. In addition, there is actually room for a fan in front of the HDD bay (already included) which allows for better cooling of the drives. The 200r doesnt Have any cooling possibility for the hard drives. Finally there's a tad more space in the back for easier/more cable management.
Not a fan of that Fractal case due to the HSF issue Tom_s brought up. Also hate how cramped it is.
What about the 300R it has a 140mm intake fan in front of the hard drives, a rear fan, and mounts for top and side fans as well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
Not at the $80 price point when the overall better featured COrsair 230T costs $70 or less. Also, having a large number of fan mounts doesn't actually mean that the cooling will be superior in some way. Bit-Tech.net found that getting more than 4 fans has some serious diminishing returns:
http://www.bit-tech.net/hardware/2012/02/10/the-big-cooling-investigation/1
And this motherboard:
MSI H87-G43 $99.00
Because I can get this:
Intel Core i5-4430 3.0GHz $149.00.
Solid choices.
Well they didn't have the 230T in stock when I went, or the Haswell processor I wanted. I did end up with a Haswell and the 300R case. Will post pictures after build.
