$800 to $1k - PC Build
cadd
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
Lots of complex Microsoft Excel spreadsheets, Netflix, programming, web surfing, some gaming (i.e. SC2, DOTA)
$800 to $1k, tax and shipping included
United States, Chicago, IL
Case, CPU, PSU, RAM, Motherboard, SSD, GPU, CPU Cooler.
SSD probably
6) Will you be overclocking?
No
1900x1200
Next 2 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0
Yes, Windows 10 64bit.
By answering these questions you help us help you build a PC that's of better quality, better performing, cheaper or all of the above.
I think you're planning a bit too early as hardware pricing and availability can change in those two months. I recommend coming back for advice when you're only 1 to 2 weeks away from buying parts.
Though a few questions:
1) What SSD are you reusing?
2) Are you within a 30 minute drive of either of these two Microcenters?
Micro Center - Computers and Electronics
3) What's the specs of your current PC?
