- Apr 22, 2002
Help me build one please! no more than $800. I have a legal student copy of Windows 7 64 already, and a monitor/mouse. Just need the machine
Please read and answer question 8 again.
Also are you planning on reusing RAM, PSU, case, and DVD drive or do you need those brand new as well? Those parts weren't part of your answers to questions 4 and 5.
9.8 years, you'd think he'd know the drill by now. Jeez
Is that better?
Better but still doesn't answer the pertinent question: 8) When do you plan on building/buying the PC?
See the WHEN?
Dude, I need to know when you're building the PC as it determines whether or not I should spend time helping you. If you're planning to build the PC in 2-3 months from now, most of the advice given to you will be more or less useless due to new hardware releases and current hardware become outdated, overpriced, out of stock, or outperformed. Hell sometimes our build lists completely changes weekly. As such, if I know that you won't be building for another 2-3 months, I don't plan on helping you as I would essentially be giving you outdated and poor hardware advice.As soon as I get some advice, which doesn't seem to be here.
In addition, a lot of our build lists uses Newegg combo deals to save you money. Those combo deals however end at the end of the month but new ones will pop up next month.
But if you don't want us to help you save money with combo deals from either this month or February, then go with this setup assuming that you can buy within the next month:
$190 - Intel Core i5-2400 CPU
$90 - Intel BOXDH67BLB3 Intel H67 mATX Motherboard
$37 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$213 - Gigabyte GTX 560 TI 1GB PCI-E Video Card
$80 - Hitachi HDS721050CLA362 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$20 - LG GH22NS90B DVD Burner
$68 - Antec NEO ECO 620C 620W PSU
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
Total: $748 shipped.
Ok, I apologize I just thought I was getting picked on, having to make so many edits
No prob. Didn't mean to appear to be picking on ya. Just had to get the right info.
Now moving past that, look through the build list and see if there is anything you want to do with it
Not a good choice since it's relatively cramped and has little to no cable management features.Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm
Good mobo but not worth it in your case since you're not overclocking.MSI P67A-C43 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
A tad overpriced considering the faster HD 6950 cards aren't that much more.EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support FPB Video .
Extremely low quality. Not worth getting unless you want a dead PC.RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready
Not worth it for two reasons:Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost)
AMD isn't a viable choice considering that Intel pretty much has them beat at almost every price point.$838.94 and I would still need a HD. I wasnt sure if I wanted to go the cheaper AMD route
Fairly sure I'm not. Newegg simply is the easier of the many computer hardware retailer sites to use and buy from. We use to do builds where parts would come from different retailers but after awhile we stopped doing that because that just takes too much time. Besides, most of the time Newegg offers the better price unless you live in CA, NJ, or TN when Newegg charges tax.I'm pretty sure some of these General Hardware list-makers are paid Newegg employees. It's absolutely retarded.
This is what I priced out:
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR
$838.94 and I would still need a HD. I wasnt sure if I wanted to go the cheaper AMD route[
Seeing your not gonna of I would cut back to a 2500pair non k version story k to stock your not gonna see a huger performance. Increase doing this should save you enough for a good he'd
