Gaming
$800 before tax and shipping
USA, Cary, NC
Video card, cpu, ram, case, power supply, motherboard
single 120GB SSD
6) Will you be overclocking?
not a priority; yes if possible after a stock build is complete
1080p, 20 inch. (can be upgraded - separate from PC build budget)
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
VM, USB 3.0, SATA 6Gb/s, UEFI - would like to not miss out on future boot features
no - Would like Windows 7 home premium 64bit
Gaming
USA, Cary, NC
single 120GB SSD
asap
