DarkKiller
- Feb 4, 2008
100% gaming, WoW, GW2, SC2, Latest FPS, stuff like that.
$800ish 900 max.
3) Where do you live?
Stockton, Ca. About an hour from Sacramento.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case, psu, processor, motherboard, ram, hard drive, and graphics card.
Mouse, Keyboard, and monitor.
6) Will you be overclocking?
Will consider it if it will help get more bang for buck.
23 1920x1080
This week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Might possible go crossfire/SLI, but most likely a single card. Unless i can get a better deal from sli.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
I own a legit license for win 7 64.
Also on a side note, I will probably wait a week or so to buy a graphics card to see how the prices come down. But I would like to get the core system together before then.
I was thinking something along the lines of this.
CPU/mobo combo http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.519523
HD/PSU combo http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.526778
G.Skil 4g ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253
Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
dvd http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
$715 after shipping and tax, should leave a decent amount for a graphics card.
$800ish 900 max.
23 1920x1080
This week.
