8 Pin Connection
Northbridge
This post might make more sense if you see this picture Link Im talking about the 8 pin CPU power connector.
Does it matter if I use an 8 pin or 4 pin connection if im doing a small amount of overclocking? I ran into the problem of my 2x4 pin cables not having enough length to reach the top of the mobo from the bottom of the case. I did buy two 4 pin extension cables but sadly I can only use one of them because they were poorly designed. If I try and connect the two side by side it won’t work as the square and hexagons won’t line up. For the record im using a gamexstream PSU which for the 8 pin connection is actually two 4 pin cables labelled "CPU 1" and "CPU 2". I only have one CPU so I think im fine only connecting the one, but I heard system stability might be lost if I overclock.
As long as you plug in the 4 pins that aren't blocked out in that picture, you should be fine. Yes, ideally, you should run with all 8-pins, but since they don't reach you should be ok with only 4 of them via extension cable.
If the pins don't match up with the round/square/etc. design, don't force it into the slot. Better to leave it unplugged than fry your board. Not sure why the 8 pin extension doesn't work unless it's designed for two separate 4-pin connectors. I would imagine that if your PSU cables did reach the board, the 8-pin design off of the PSU would match the motherboard perfectly.
