ITSTHINKING
- Mar 1, 2006
Hey guys I had a question. I am building my buddy a new pc to replaced his burned out e8400 rig. He is using an older but healthy corsair 650tx power supply. The motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519) has a 8 pin atx connection and I can't get the thing to post. In the past I have have seen rigs that have these but would post if even if a 4 pin was plugged in (although obviously it's not ideal). I was reading around and a gentleman on a different website had an i7 rig that wouldn't post until he bought a 4 to 8 pin adapter which I already went ahead and purchased. Now I know ideally my friend should pony up for a decent PSU with a proper 8 pin 12 volt atx plug but right now he simply cannot afford it. I guess what I am getting at is should this work? I swapped ram, and the LEDS on the video card turn on and power up fans spinning no squeals of death from lack of power. The interesting thing is that the fan on the CPU spins and stops immediately with the 4 plug inserted, but when I unplug it (24 pin still intact) the fan spins as if the board is getting the juice it needs, just not the processor oh which is a FX8350 in case that matters. Any input would be appreciated, curious if anyone else ever ran into this. I find it interesting that some motherboards have 8 pins and will work with a 4 pin, but from what I read, it's good for overclocking and such. Oh well another 3 days I shall wait to see.
edit- http://hardforum.com/showthread.php?t=1728376&highlight=pin this makes me a bit hopefull that the adapter should work, even though a different platform exact same problem
