7970 high idle/load temps in reverse atx case
TurboGLH
Getting high temps, 53 idle and 85 under load in my pc-v1000. Wondering if the heatpipe type heatsink is unhappy being run in the reverse orientation. Idle temps go up to 62 when overclocked since idle clocks go to 400 core vs 350. Any feedback?
Though 53 and 85 are not great, their not too bad either. I wouldn't really worry about it as long as everything is working fine.
My bigger concern was the o/c idle of 62. Almost 20 more that the hard review. Works fine, just loud under load. If its an issue with the card I want to return it before the 30 days.
I'm running an FT02 case (reverse orientation) and the card is idling at 36c at 20% fan speed. Ambient temp in the room is 65f. As I have mentioned in other threads, the first 7970 that I bought would run MUCH hotter, idling at 49-52c and hitting 90-95c during load.
Did you buy another and rma the first or did they cross ship on the rma?
Dang, well i posted just about that on the other thread, check the way your card's vaporchamber and heatpipes are orientated, follow the advice on this link and it will let you know if the problem is the card itself or the combo configuration:
http://forums.anandtech.com/showthread.php?t=2204972
I'll check that. Thanks.
idle temps with just one monitor?
my idle with 2 or more monitors displaying is 61c but with just one monitor its 40c.
Idle temps of ~60C are normal if you've got more than one monitor connected it seems. As soon as I plug in my HDTV temps rise to 60C, up from 38C or so.
Hmm. Ok, more to consider. I've got 3 x 24" acers hooked up, I'm going to try and disable the two outer displays and will report back.
Thanks for all the input from everyone.
it's definitely because of your multiple monitors. see my post here about this. that was at stock settings. now that i've overclocked my card idles at about 54 C with a custom fan profile.
Those numbers were for 1 monitor (Dell 3007WFP) First card I had would idle there. The replacement is idle @36-38
Yup, 2+ monitors enabled and it runs the core speed a bit higher and full 3D speed on the memory. Kinda weird.
yup more than 1 monitor leads to higher temps - mine is idling around 60 degrees - but then its summer this side of the world.
