how is the new 7970 "ghz" is it better, does it perform better than before? is it a competitor for the 680 gtx?
thanks
i have 2...they are very quiet...
do you have your tower next to your head?
sorry, you sound like a troll..
Every test on the weg has shown that the GHz edition is loud. So his experience sounds legit, yours on the other hand does not.
He specifically asked about the GHz edition.
It is pure fail from AMD to let sites review a configuration that won't be released by the majority of partners. Some (Club3D afaik) stick with the reference solution in all aspects, so one would have to watch out there.
i have none of those issues..
and i have an x-fi HD platinum as well...
although i do have the sapphie dual-Xs....so i suppose i wouldnt know about stock...
Its kinda odd but my HD 7970 Sapphire reference based is barely noticeable to hear, even after the BIOS flash to make it GHz edition. It still quieter than the rest of the fans of my relatively old Antec 900 case, may be that depends of the games and the load it can put on the GPU.
however, given the option, who in their right mind would buy stock?
yeah correct. there are so many good custom coolers like Gigabyte Windforce, Sapphire Dual X, HIS IceQ, Powercolor PCS+, MSI Lightning so anybody who picks the stock cooler has no one but himself to blame.
To the OP question, the ghz cards arent meant for 1 monitor but multimonitor setups with really high resolutions - hense the 6gb of memory. I wouldnt buy it if you only have 1 monitor setup. As one person said theres multiple cards available that are stocked overclocked if youre just looking for a fast card.
Hey mates.
I might have just found a solution here as I broke my 7970 trying to do this, but gigabyte has a jumper/switch for dual bios? what do i do to flash the old bios back? either directly through the switch or with my old bios saved.
