7950 which
John117
I am from India and i want to buy a 7950 Card
Stuck Between:
MSI R7950 TF 3GD5/OC BE (is it voltage locked ?)
http://www.msi.com/product/vga/R7950-TF-3GD5-OC-BE.html
Sapphire AMD/ATI VAPOR-X HD 7950 OC with Boost (is it voltage locked ?)
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1157&pid=1547&psn=&lid=1&leg=0
Rejected:[If you have any thing to say regarding rejected brands please do share your opinion]
GIGABYTE - 7950 windforce ... (rejected due to poor service in my area as told by other buyers) (Still i like its cooler but i heard that its voltage locked)(is it voltage locked too?)
http://www.gigabyte.in/products/product-page.aspx?pid=4121#sp
XFX - Not very popular here + availability issue
ASUS - too big 3 slots its too big for me
HIS , Powercolor - Not available here
So which one should i buy
The MSI model have some problems with the fans.. that would spin at 100% over 65C and make a lot of noise.. and you will have to RMA it...
so go for the Sapphire.
Get the Gigabyte if you're ever going to crossfire with a two slot space, the Sapphire isn't two slots.
I personally bought the Gigabyte HD 7950 Windforce card, and it's simply amazing (though any HD 7950 will likely perform similarly). It has very effective cooling and is MUCH quieter then I expected it to be. Can't vouch for "poor service" in your area or not, since it will certainly vary depending on what global region you live in.
But honestly, performance wise, ALL HD 7950's will perform the same (more or less), and are likely to OC to similar degrees. You need to find out what's important to you.
Such as:
- Voltage locked/unlocked
- How many slots (2/3)
- Type of cooler
- Factory OC'd
- Reference design (Important for Water Cooling)
and so on.
Once you know what particular things you find important, then we can help you decide on a specific card. Otherwise, as others have said, buy whatever is cheapest.
Picked up the MSI a couple of months ago from Microcenter and it was not voltage locked.
Has been serving me fine with none of the fan issues that Drangueos mentioned.
I have had two msi 7950 tf3's. one boost and one normal version. Both had 6+8 pin connectors, dual bios, unlocked voltage, and not a single problem. Never heard of the fan issue, but you can control fan speed with msi afterburner. Both overclocked great. I'd go with whatever is cheapest. I do like msi's transferable lifetime warranty
Whichever is cheaper
most probably sapphire is cheaper
Really what kind of noise problems exactly
Isn't two slots ?
SO
i selected Gigabyte GA Z77X UP5 TH
Slots used =>
1.Wifi Card
2.If i use the Sapphire Card Here
3.can i use this card here
http://i.imgur.com/AyH8htg.jpg
http://i.imgur.com/srTiV80.jpg
http://i.imgur.com/Zrsf8hc.jpg
http://i.imgur.com/alMF0YF.jpg
http://i.imgur.com/TMmWIrJ.jpg
^^ this question is for all ^^
Such as:
- Type of cooler
- Factory OC'd
and so on.
is Gigabyte one is voltage locked ?
i want
2 slots , voltage unlocked , factory OC , no Watercooling , low noise
OK So its just a faulty fan then i guess
OK i will find out which is cheaper
Please answer the question about 'Slots in Motherboard '
What is MSI transferable warranty ?
