quicksilver98
- Nov 3, 2004
So I built this machine for a friend a week ago and he finally got his graphics card. When it was installed it wouldn't boot into windows, but would post and get to the loading screen for Windows 8. I've tested the components and they all work. If you boot the machine off of just the HD4000 it's works flawlessly.. I've check for bios settings and told the machine to Initialize the PCIE slot first...
I've tried the following troubleshooting scenarios-
1. I booted the machine with no video card into windows successfully
2. I booted with the AMD 7870 installed and it posts and shows the windows 8 loading screen then the machine locks.
3. I tried an known working AMD 7850 in the machine and booted with the same outcome as 2.
4. I then tried using a 5450 AMD card in the machine and booted with the same outcome as 2 and 3.
The system is as follows -
i5 3570K
Asus P8Z77-V LK
2X4GB Corsair DDR3 1866
XFX 7870 Double Dissipation
Corsair HX 650
Xigmatek Gia with 2 Corsair 120MM SP120 Performance Fans
i5 3570K
Asus P8Z77-V LK
Corsair HX 650
