FragMastahFlem
- Jan 9, 2004
Matrox462 said:If i remember correctly off-hand, it's a setting that limits the framerates according to your refreshrate on your monitor, so as to prevent any image 'tearing'. It shouldn't effect performance at all.
Retardo said:i turned mine on and it made CS run much more smoother but made the FPS drop...max 60
FragMastahFlem said:while we're at it, can someone also explain Anisotropic(sp?) Filtering?
Circuitbreaker8 said:so let me get this straight, the screen only tears when the fps goes OVER your max refresh rate?
Matrox462 said:Correct me if I'm wrong, but once your framerate gets to a certain level, anything beyond that shouldn't be visible at all. If framerates are going past your refreshrate, how could you possibly see those extra frames being displayed, since it's already meeting the rate at which your screen is showing images. Losing some fps because its past a certain level shouldn't sound like a bad thing, since it's something that shouldn't make any difference at all...
I could be wrong though
Bottom line is just try it, and use what works, and what is the smoothest
burningrave101 said:If your average fps is PAST your refresh rate then no, v-sync isn't going to make a noticeable difference as far as cutting your fps. If your fps is below your refresh rate though, v-sync is going to cut it in half. And if your fps are lower then half that of your refresh rate then i believe it cuts it in half again.
I'm not real positive on all this. It would be nice to see someone that knows alot about it chip in. I've seen alot of different opinions on it though but i found the best information on it from the nV News forums. Try going there and doing a search for v-sync if you want to find out more.
I just leave it disabled because if i'm getting over 85 fps (my refresh rate is 85Hz), i'm definitely turning up the IQ more.
Matrox462 said:I imagine if it's below the refresh rate, it wouldn't drop your fps... It wouldn't make sense to do that, as the only time the v-sync is needed is when it goes above it. I too am not too sure about all this... so I don't know.
And I also do what you do, if my framerates are *that* high, then something needs to be turned up to look better!
EDIT: I just got to wondering if v-sync is only a CRT thing... I imagine it is since refresh rates have no effect on LCD screens as long as it's within the range of the LCD... I wasn't thinking lolSo used to using LCD's for years!
