780G - issues with 1080p playback
uberowo
After considerable effort I have found that I am simply unable to make my HTPC play 1080p .mkvs. I have major issues with stuttering and/or audio desynch. The computer was bought specifically for this purpose so it's pretty damn annoying. :D (I've had the computer for quite some time now, but only recently I've been trying to make the jump from 720p to 1080p and thus have been reminded of this issue.)
I've tried a bunch of different players (KMplayer, Zoomplayer, PowerDVD, MPC) and I've tried installing a buncha different codecs as well as clean installs of windows vista and recently windows 7.
The problems are constant, though some players seem worse then others. I'd GREATLY appreciate ANY input.
This is the DXdiag info I thought might be relevant:
System Information
Time of this report: 3/29/2010, 17:19:56
Machine name: HTPC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-MA78GM-S2H
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Dual Core Processor 4850e (2 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3838MB RAM
Page File: 1161MB used, 6513MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 192 DPI (200 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
Display Devices
Card name: ATI Radeon HD 3200 Graphics
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x9610)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9610&SUBSYS_D0001458&REV_00
Display Memory: 1916 MB
Dedicated Memory: 253 MB
Shared Memory: 1663 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: Panasonic-TV
Monitor Id: MEIA07D
Native Mode: 1920 x 1080(p) (50.000Hz)
Output Type: HDMI
Driver Name: atiumd64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.14.0010.0678 (English)
Driver Version: 8.632.1.2000
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/18/2009 02:15:58, 4059648 bytes
Sound Devices
Description: Digital Audio (HDMI) (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_791A&SUBSYS_00791A00&REV_1000
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/14/2009 02:07:00, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
I found that with my setup, the onboard HD3200 (780G) graphics were not good enough to play 1080p content in Windows 7, nor could I use the guide and watch live HD channels at the same time in 7MC. Before I upgraded to Windows 7, I was running XP, and I had some issues with 1080p content at first, but somehow, after installing CCCP and running MPC, and tweaking the settings, I was able to get hardware acceleration working, and 1080p files played fine (under XP only). However, after trying out Windows 7 RC, and then upgrading to Windows 7, I could not reproduce those results. I eventually gave up trying, and bought a stand alone card (one of the new 5450), and haven't had any issues since. There may be a way to get 780G to run 1080p files, I just couldn't figure it out. Having a slower processor didn't help either. It wouldn't hurt to try the guide above, but you may need to upgrade your video card or CPU, or go back to XP.
