7800gt VS. 7800gtx
2 7800GT's in SLI
but if you have any plans of putting a GTX in now and one later, that would be good too.
i would opt for the single gtx. sure, the dual gt's will out-perform it, but the $300 extra that it costs could be well invested elsewhere. unless money is no object, but in that case, y wouldnt u go for dual gtx's?
I would stick with a single 7800gtx since not all games SUPPORT SLI. This mean u got a game from a 3rd party u might notice 2fps benefit. I would get a 7800gtx by the time it gets outdated or too slow u can always get a 2nd gtx cheaper or a new card.
i personaly wouldnt buy 2 GTs, they arnt going to be better then 1 GTX in every single game. in lots of games they will be better, but if i was going to SLI it would be with 2 GTXs
with that said, 2 GTs will NOT disapoint
The only difference between the GT and the GTX is:
4 Pixel Pipelines
1 Vertex shader
And the GTX has higher clock frquencies.
Other than that, the performance you get from each is VERY similar. So definately two GTs in SLI would whoop one GTX.
1 7800GT. Save your money and just get one GT. This card will slaughter anything out there and cost $100 less than the GTX. 2 7800GT's in SLI would be a waste...its overkill. Yes you may be able to do 160fps in BF2 at 1600x1200 but the human eye cant even detect a difference in frame changes above 70.
Bullcrap....that's a generality, and simply, completely, untrue. The AVERAGE moron might not be able to tell the difference between 70fps and 160fps...but lots can, me included. Computer games are NOT like watching TV....
I'm not sure why there is so much debate here, 2x7800GT in SLI will murder a single 7800GTX, period. New games that don't support SLI are a rarity and in the minority.
In the long run you'll want the GTX in SLI. Buy the GTX and later down the road when they come down in price drop another GTX in your rig. You'll be much happeir in the long run.
At this stage in the game I'm not sure that is smart. Next year video cards will come out with Unified Shaders/WGF2.0/DX10 and no amount of 7800GT/7800GTX cards will get you that architecture or featureset which seems to be emphasized for Windows Vista.
I say buy the 7800GTx2 SLI now, enjoy the performance, When you need to upgrade, sell the 7800s and buy a unified shaders card. A lot smarter than another 7800GTX down the road IMO.
