amish_p0rnst4r
- May 18, 2005
Ok so here's the deal....
I already have the following for my new build...
Build will use 1/2" Fittings/Tubing (7/16" Tubing Possibly)
D5 Pump
DD BIP 120.2 Radiator
DD Fillport
Apogee CPU Block
Panaflo 120mm Fans
So my problem is kinda this....
I'm looking for a waterblock for my XFX 7800 GT Vid card (I'd perfer one that cools ram the pads also mainly for astecically pleasing value) Otherwise I'll just be going with a Silverprop CycloneFusion HL...
Now from my research I find the -
Nv-78 from Danger Den that uses 1/2 barbs
The following state they use 3/8 or 1/4 fittings so would adapters be a waste of time on my loop with one of these
I mean if not how would you go about connecting them
Innovatek g70 -
http://www.frozencpu.com/ex-blc-179.html
Aquagra 7800
link is to the 6800 but same fittings
http://www.sharkacomputers.com/aqcoaqfx68r2.html
Koolance l06
http://www.frozencpu.com/ex-blc-147.html
D5 Pump
DD Fillport
Apogee CPU Block
Panaflo 120mm Fans
Innovatek g70 -
Aquagra 7800
Koolance l06
