yea thats what i did. i didn't feel like screwing screws into the heatsink.Entropy1982 said:Ok... newbie alert![]()
I want to ziptie the fan onto the heatsink of my BFG 7800GTX OC
Do i have the right idea?
http://i13.photobucket.com/albums/a...982/topdown.gif
http://i13.photobucket.com/albums/a...py1982/side.gif
I know i know.... i'm sorry![]()
should i attach spacers (with zip ties) to the fan?damstr said:yea thats what i did. i didn't feel like screwing screws into the heatsink.
yea it's a dam nice free mod since im using an XP-120 with a 120 panaflo for my CPU heatsink.HighwayAssassins said:wow...nice mod...and i imagine if you have a 7800GTX you probably also have an A64, and chances are if you have that combo you are not using the stock heatsink, therefore you would think this would be a free mod for most people.
Nice find!
can you turn on Flash on your cam pls?damstr said:i just tied 4 zip ties together and went around the card, and put the second one hooked onto the plastic fan guard. heres a pic:
Entropy1982 said:can you turn on Flash on your cam pls?i can't see what's happening there lol... what do you mean you tied 4 zip ties together?
Mnx4 said:What are you talking about? What were your temps before? 45C idle isn't that bad (at least not for me). What are load temps looking like? Are you just unimpressed by the cooling or something?
i don't know dude, my idle temp went down about 10-12C and load went down 20, so it can't be too much better.tsuehpsyde said:My cooling mod is better.
Never checked load, but idle went down 8-10C, and chipset went down 8-10C too. Gotta love that.
damstr said:i don't know dude, my idle temp went down about 10-12C and load went down 20, so it can't be too much better.
hmm... wonder if i can do your mod AND the normal mod =Ptsuehpsyde said:Oh, I was just being sarcastic.Not sure how well it runs compared to this mod, but I do know that mine requires no card disassembly at all, which is worth that 2C difference. And the fact that it's acticely cooling the back memory too = better memory overclocking.
peleejosh said:The people that have done this mod... Do you leave the stock fan plugged in or do you unplug it?
I have a BFG 7800GTX OC.... would i need to do this as well?peleejosh said:I think for the BFG you have to take off the entire HSf first and then like you said remove the little screws holding the plastic cover on
acroig said:I unplugged mine. The noise level went down dramatically. I hooked up the A64 fan to the mobo. As the card's temp goes up the fan speeds up. Fantastic.![]()
