780 SLI - weird clock readings?
290X
Both 780 Lightnings, which have a core clock of 980mhz and a boost clock of 1033mhz
Any idea what's going on here?
Now things get weirder.. the cards are not being overclocked in any way, but GPU-Z also reports the same while running the render test.
Edit: according to GPUZ, both cards are running at 1110.5 under full load.. so... I guess I'm just gonna roll with it.
Kepler cards boost higher than their rated spec always. The base/boost clocks are basically minimums, not "what it'll do under gaming" :). Running the render test is putting load on both cards causing them to go to their gaming-level clocks, hence why they both go to 1110 at that point. When idling you may have had something small like a GPU-accelerated web browser or other thing causing just one card to clock up but SLI to not kick into 3d mode, so one card stayed at a lower clock.
Actually, I was playing Batman: Arkham Origins, and the performance was sub-par, not only that but the one card wasn't going any higher than 25% TDP for some reason (the top card).. so I rebooted the system, fired the game back up, and then both cards started working properly again, not only that but both are running at 1110, so I'm pretty happy with that.
I guess there's a lot of truth in the old "have you tried turning it off and on again" adage.
