MacLeod
- Jul 28, 2009
Hey guys, Im still a little green on OC'ing so I wanted to run this by everybody and make sure it looks alright.
I tried 3.3 but it wouldnt even run the Windows Experience thing-ama-jig so I went down to 3.1 and it hit the BSOD when running Prime95 after 10 minutes. I set ACC (SB710) to AUTO and 3.1 ran fine in Prime for several hours.
I wasnt going to try 3.2 but the benchmarks in Overdrive made a HUGE jump from 3.1 to 3.2 so talked myself into it. Tried the Vcore at 1.385 but couldnt get Prime to run longer than 10 minutes. Gradually increased the voltage and finally at 1.425 it has been running Prime now for the last couple hours along with my surfing online with no problems so Im assuming its ok. How long do I have to run Prime95 before I know for sure my OC is solid?
Also, Im worried about is 24/7 usage. Do you think this is too much voltage for this CPU long term? Temps so far while running Prime and internet browsing have hovered in the 45-49 degree range and never went over 50 that I saw anyway (running stock cooler). I adjusted ONLY the multiplier and voltage and did NOT touch the FSB clock and did NOT touch RAM settings at all. Granted I suffer from severe upgraditus foresee an X3 720 in my future once they get under $100 but I dont want to kill this one prematurely. All I do is internet, games and occasionally a photo edit or two.
