Machine specs: (girlfriend's rig)
MSI 880gm-E41
Athlon X2 250
Msi 7750 catalyst 12.8
Seasonic 350w
WD 300 GB velociraptor
Ok weird issue. With a GTS 450 and a GTS 250 I have been able to get this chip to 3.75 ghz and everything works. With this 7750 installed it hangs the system any time I open CPU-Z or HW monitor, only with the video card driver installed. Then on reboot it says a HT sync flood error has occurred. This is at stock clocks on everything. If I uninstall 12.8 it works fine. I have tried several different catalyst versions, wiping and reinstalling till Im blue in the face etc.
Also I have tried overclocking without the driver installed and then not touching cpu-z. When I do this and then reinstall catalyst, it fails prime 95 right away(although it does seem to work at stock clocks). Does anyone have any idea short of going back to nvidia. I no longer have the gts 450. I went with the 7750 due to the performance per watt ratio.
MSI 880gm-E41
Athlon X2 250
Seasonic 350w
