750TX -> 650TX
vertigomhs
would you guys say its worth it to return my 750tx and buy a 650tx for essentially the same price?
i bought the 750tx without reading any reviews, and found out it wasnt the greatest psu, i bought it because it was the same price as the 650tx, and thought i was getting a deal.
but after reading up on the 650tx, it seems to be a far better psu, so would you guys say its worth it? the 650tx would end up being $10 cheaper in the long run after the MIR, and i get a better psu, but are the differences negligible?
The differences are negligible. Keep your 750TX.
The TX650 is a better PSU, but unless you're running your TX750 to the ragged edge (you aren't), there isn't any major reason to switch.
