I'm looking to start from scratch and build a new pc.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc.
Probably some Photoshop, moderate gaming, web/email, etc.
I'm trying to keep it around $600-700 if possible, but I want to keep it good quality also.
3) Where do you live?
Atlanta
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything, starting from scratch.
None
6) Will you be overclocking?
Possibly, not too informed on the subject as this is my first build.
Gonna go for around a 22-24 inch monitor.
2-3 weeks around the holiday times and try to find some good deals.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
Found a case already, but let me know if its good.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125286
Not really familiar with all the options so let me know if there's something better suited.
Was using this thread to help me get started but don't think I need video cards and motherboards as expensive, etc.
http://hardforum.com/showthread.php?t=1470412
And that's about as far as I've gotten.
Thanks
Atlanta
None
None
Yes.
Video Card:
Thanks
