How do you bring that up?
How to you chek this? what should i click, and does it work for 6970?
Also what version og GPU-Z i need to use?
What does this mean exactly?
Sapphire 7970 OC edition: 84.1%
But it can't overclock for shit (1095 stable, at any fan speed/voltage)
90.1%Sapphire 7950 950mhz edition. Overclocks like a monster, just can't control VRMs on air. Can game at 1225mhz core on air (accelero xtreme 7970 cooler). Elpida RAM, though
So literally no overclock headroom there.
I've got a MSI Twin Frozr 7850 that has an 86.3% ASIC. This card overclocks like crazy without any voltage adjustment since it doesn't have software voltage control. So far I've been able to get 1150MHz core and 1450MHz memory stable in all games and benches.
I've also got a Gigabyte Windforce GTX 670 that I haven't started overclocking yet but has a 100% ASIC so I don't know if these numbers mean anything or not, but we'll see when I start overclocking the 670.
My understanding of ASIC (at least for 7000 series cards) is that high ASIC scores means less current leakage.
Hooded Dutchman, my stock VRM cooling is stronger than the Acceleros cooling (that's not to say the Accelero's is poor, it's just comparatively not as good). I hjave left that on, and mounted the Accelero cooler.
As I have such a high ASIC score, I have a lot of heat created at lower voltages. My VRMs get too hot at anything above 1.139v (at 1.139v I can game at 1250mhz). Stock cooling is not enough at that voltage for this card. It's a hard beast to tame, but once you can control it a bit it can push insane clocks at low volts.
On the other end of the scale, I can game at stock core clock (950mhz) at 918mv (down from stock of 1012mv) stably. Even lower possibly, just haven't tried.
Your DualXs at 1.3v were undoubtedly low ASIC scoring, and wouldn't break 1200mhz I imagine. My card would explode at 1.3v. Mine is 1250 on air, and I've no doubt I could break 1350 on water (FFS I am only at 1.139v as it stands).
I have a similar card; it did 1200 @ 1.138v --- ASIC 86.8%
Water only takes it to 1300 @ 1.219v. Beyond that it hits a temp wall, like it did previously. Needs sub 40c for 1300 to yeild no artifacts in OCCT; still game stable above. However anything more and it must need sub 35 or so.
So, I'd imagine you would hit around 1325-1350. Depends on your temp wall.
add 5770's to that sentiment :-/Its not supported for 6970![]()
