Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
there are plenty of psu's that claim large maximum wattages but still kill components due to being poorly engineered and generating dirty power (inexplicable power lows).
Well are you asking whether or not a Thermaltake 700W PSU is good enough for your system? Or are you asking if a 700W PSU is good enough for your system?
And AFAIK, all of Thermaltake's 700W PSUs are Toughpowers. So if you have or plan on getting a Toughpower, you're set. Besides the Toughpowers, Thermaltake's Purepower RX line of PSUs are pretty good.
A good quality 700W PSU from an excellent PSU company (Corsair, PC P&C, Seasonic, Thermaltake Toughpower, Enhance, etc) more than enough for your system.
it'll power it with more than enough room to spare!
personally i would go with a different brand however, as my toughpower 750 watt is a tad on the noisy side, but other than that, works great!
