$700 Gaming Build -- 2500k
tonytnnt
See build ideas below form.
A friend of mine is building a new gaming rig so he can play Borderlands 2, plus other games that come down the pipe.
$700. Tax and shipping included.
Minneapolis, MN (Microcenter is nearby)
CPU, RAM, Motherboard, GPU, PSU, Case, Storage Drive, DVD Drive, SD memory card reader
Old Monitor (will upgrade at Christmas), mouse and keyboard, 2 TB HDD currently in an external enclosure and used for backup
6) Will you be overclocking?
Unlikely
7) 7) What is the max resolution of your monitor? What size is it?
Plan for 1080p
Now+2weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SATA 6Gb/s, USB 3.0, Crossfire a bonus
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes
Microcenter (tax included)
$172 - Intel Core i5-2500k
$59 (before $10 MIR) - Biostar TZ77A
Microcenter Total: $230.64
Newegg
$60 - Antec Neo ECO 520C 520W
$40 - NZXT Source 210 S210-002 White w/Black Front Trim “Aluminum Brush / Plastic” ATX Mid Tower Computer Case
$18 (promo code EMCNCGJ39 for free shipping) - Sony Optiarc 24X DVD Burner
$260 (before $20 MIR) - XFX FX-785A-CNFC Radeon HD 7850 Core Edition 2GB and G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
$6 - SYBA CL-CRD20061 All-in-one USB 2.0 Black Color Ultra-compact Design 5-slot Memory Card Reader Built-in USB Cable
$90 - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s
[strike=]$70 - Seagate Barracuda Green ST1000DL002 1TB 5900 RPM SATA 3.0Gb/s[/s]
Newegg Subtotal: $473.93
Newegg Shipping: $14.70
Newegg Total: $486.62
Build Total: $717.26
Options
Amazon
$50 - NZXT Source 210 -Inches ELITE-Inches Midtower Case with 3.0 USB - White (free shipping, prime eligible, also available in black)
So, what parts in the above are suboptimal for this build? Any way to fit a SSD into it while staying below $700? My friend mentioned taking his 2TB external out of the enclosure and using it as his hard drive in addition to an SSD, but then he'd be left without a backup drive. Is a Radeon 7850 overkill for the specified requirements?
It's not really recommended to use "Green" drives as primary drives. They are more-or-less designed to not be used frequently. Such as using them as backups/storage/extra drives.
I agree with Skillz. You'll hate that Green drive as a primary. Grab a nice Samsung F3 or WD Black 1 TB drive. They cost a bit more, but you'll be happier in the long run.
Get the NZXT Source 210 Elite from Amazon. With Amazon's free ground shipping, the Elite version of the case is well worth the extra $10.
As Tiraides said, get the Elite version of that case from Amazon.com. The extra 140mm fan and the front panel USB 3.0 is well worth the extra $10.
If this wasn't a major gaming PC or if you were only playing D3 or SC2 and if you didn't live near a Microcenter, yes you can. But since this is a major gaming PC and you do live near a Microcenter, no realistic way to add a SSD unless you're going with low performing and/or low quality parts.
Nope. It's just right.
One more note for ya. If you want to xfire with that PSU in the future you'll have to buy molex adapters since the 520 NEO ECO only has 2x PCI-E plugs. If you really want to have the possibility of xfire then upgrade your PSU to somthing like this:
SeaSonic M12II 650 SS-650AM 650W ATX12V / EPS12V SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Semi-modular Power Supply $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151106
