Azzyquemint
- Sep 30, 2010
Gaming
Maximum $800, though if I can shave a few dollars off without significant impact on performance, I would appreciate it.
San Francisco, California
Motherboard, CPU, RAM, GPU, SSD
Antec Earthwatts Green EA-430D 430W PSU, 3 years old
Cooler Master CM 690 II Advanced - Mid Tower Computer Case w/ 3 stock fans
Sceptre X270W-1080P (27")
Samsung 1 TB Spinpoint 7200 RPM 32MB Cache SATA, 3 years old
Western Digital Caviar GreenPower 1TB SATA Hard Drive - 16MB (or very similar), 4-5 years old
Keyboard
Mouse
Headphones
6) Will you be overclocking?
No.
1920x1080
27"
I plan to order all the parts no later than Friday the 11th.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No specific needs. Just the best I can afford, please. I do not plan to use more than one GPU.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Nope.
ASUS Micro ATX DDR3 2400 FM2 Motherboard A78M-A $68.24
AMD A10-Series APU A10-7850K AD785KXBJABOX $169.97
Kingston Digital 120GB SSDNow V300 SATA 3 2.5 with Adapter $54.99
Windows 8.1 System Builder OEM DVD 64-Bit $94.57
Mushkin Enhanced Redline 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) $129.99
HIS IceQ X² Turbo Boost Clock H270XQMT2G2 Radeon R9 270X 2GB 256-Bit GDDR5 PCI Express 3.0 x16 $189.99
With tax and shipping:
$421.69 from Amazon
$361.51 from Newegg
$783.20
[EDIT]: Forgot to mention I have two 1TB HDDs for storage.
Gaming
Keyboard
Mouse
Headphones
No.
1920x1080
27"
Nope.
$421.69 from Amazon
$361.51 from Newegg
$783.20
