I just noticed this, I'm slow I guess. For all the talk of 5870 and 6870, there's another pitfall.
Why AMD why.....![]()
I'm slow I guess.
The 6970 will be slightly slower than 5970 but well ahead of the GTX 480.
The 6990 will be beyond anything we can imagine, probably exceeding 480SLI.
You are severely underestimating mine and several other peoples imagination I think.
Either that or Trolling.
It is obvious to anyone who thinks about it, that without a process shrink you aren't going to match the top performing Dual GPU with a Single GPU on the same process.
For similar performance, I would take the 6870 over the 5970 anytime of the day.
AFAIK, the 5870 was only sligthly faster than the 4870X2.
don't you mean 6970?![]()
look at it like this.. The performance increase from the 5770 to the 5870 was Huge.. So if shit plays out with the tone AMD has already set then we should see a comparable gap between the 6870 & the 6970.. If thats the case then the numbers will be HUGE.
Well I'm running 5850 cf and I can't wait to "downgrade" to the 6970. No more profile or scaling issues for me no sirI'll have an extra slot to try a physx card too. It better have at least 1.5GB framebuffer though.
Radeon HD 6970 (Cayman XT) 3DMark Vantage test results floating around in the X12000, but P mode is P24499. 在Unigine Heaven (1920 1200 4AA+16AF)环境设置下运行速度为36.6帧。 In Unigine Heaven (1920 1200 4AA +16 AF) environmental setting speed was 36.6 frames.
HD 5870 3DMark Vantage获得P19337的成绩,在Unigine Heaven (1920 1200 4AA+16AF)运行帧数为17.3 。 HD 5870 3DMark Vantage P19337 results obtained in Unigine Heaven (1920 1200 4AA +16 AF) running 17.3 frames. 同平台下GTX 480 3DMark Vantage获得P21106和X9309的成绩,在Unigine Heaven (1920 1600 4AA+16AF)速度为29.5。 The same platform GTX 480 3DMark Vantage P21106 and X9309 results obtained in Unigine Heaven (1920 1600 4AA +16 AF) speed is 29.5.
毫无疑问Radeon HD 6970(Cayman XT)将会是单卡之王 ,在相同状况下超出GTX 480性能10%以上,从测试中来说具备压制性的实力。 There is no doubt Radeon HD 6970 (Cayman XT) will be the king of a single card in the same circumstances beyond the GTX 480 performance above 10%, from tests run with oppressive power.
不过这张卡依旧是内部样卡,板型类似5870,核心频率在800MHz-900MHz范围内,供电接口为6+8,相信TDP应该在255W或者以上。 However, the card is still within the sample card, similar to plate 5870, the core at 800MHz-900MHz frequency range, power supply interface is 6 +8, I believe should be 255W TDP or more.
