SupraSaiyan
- Apr 11, 2008
Which of the two is the better setup for BF3? I can get them both for same price. Bf3 at 1920x1200
Thanks
Thanks
Just to make things worse, I also found 2xgtx295 for same price as 2x6850 and 2x5850... Are 2xGTX295 better than 2x6850 for bf3?
HD 6850 crossfire. Better performance and as master noran said, runs cooler and uses less power.
I think a single HD 5850 beats a single HD 6850 but in crossfire the 6 series is seriously miles ahead.
This is not true. I have two PC's, one with dual 5850's and one with dual 6850's. The 6850's are slightly faster than the 5850's out of the box mostly due to the much higher core clock speed 725MHz vs 900MHz. However when the 5850's are overclocked to 800MHz, they easily overtake the 6850's due to having more shaders. When overclocked to 850Mhz, they are a good bit faster than the 6850's even when the 6850's are overlocked to 950Mhz.
In a nutshell, out of the box, no overlocking, the 6850's are slightly faster, in DX11 games with a lot of tesselation, the improvements are little more noticeable since the 6xxx series has better tesselation performance. Otherwise with a little overclocking the 5850's can be made to really blow past a pair of 6850's even overclocked.
That being said, the 6850's are slightly less power hungry, and I do mean slightly. The 6xxx crossfire scaling improvements over the 5xxx series is a little blown out of proportion because I'm just not seeing that in my setups.
Thank you. I was just looking at that same performance earlier, and the 6850's even with their higher clocks aren't way faster than 5850's. Just slightly I'd say, and that even really depends on the game played.
Looks even according to this. I was expecting the 5850 to pull ahead. Kinda shocked.
Just google 6850 CF issues first before you buy them
Forget about clock speeds and that crap just look at one thing
ATI 5850
Processing power (single precision): 2.09 TeraFLOPS
ATI 6850
1.5 TeraFLOPS
What 6850 comes clock in at 900mhz please let me and everyone else know.
900Mhz? I think he is refering to 6870. The 5850 outperforms the 6850 by almost 20% in BF3 and only a hair slower than the 6870
And yes overclocked to the same clocks a 5850 will also outperform a 6870 obviously.
I just came from a 5850 to a 6870 and both overclocked, I found the 6870 to be smoother, that was metro2033 and BF3. ive just added a second 6870 and now can max everything out...one thing to remember is the 6 series scales better in Crossfire than the 5 series does
The 6xxx series is slightly faster than the 5xxx series when using DX11 games because of tessellation, in DX9 and DX10 games they are preactically identical at stock clocks. As for the 6xxx scaling compared to 5xxx scaling, that's a load of horse manure. They both scale about the same.
Yup. Its all down to drivers which can make or break CF scaling. If there is any innovation in hardware architecture that directly improves scaling AMD will be all over it in their 6000 series marketing presentations. And I can never understand the logic of going 6850 over 5850 just because they scale better in CF but slower in single card operation. When CF doesnt work, isn't the faster single card more beneficial?
