680i slow download speed
xxm12mo17k13xx
i got a evga 680i and for some reason my download speed is super slow. i've tested the speed on another computer and it works fine, but only on the 680i does the speed slow down. anyone have this same problem as i do?
I didn't have any issues with my 680i SLI and I have no issues with my current 680i LT. That said, make sure you're running the latest drivers for the onboard NIC, as the previous poster suggested, and if that doesn't fix it try moving the machine to a different port on your router. Also make sure that no two machines on your local network are using the same machine name in Windows, as this may cause networking problems.
yeah i've tried all that already. i got the latest bios and drivers. i tried all four ports on my router. it's driving me crazy because this only happened when i started using the new motherboard. i've read other posts that said i should just install a pci NIC card but i shouldn't have to do that since i already got it integrated. i don't know...i'm open up to any suggestions.
How many other machines do you have on the network? What router are you using? Is this a new machine you're adding with the 680i, or did you replace the motherboard on an existing machine?
Is this 100mbps or gigabit?
If you're running 100mbps, auto-negotiation can be subtle. A duplex mismatch will kill link performance.
If you set your motherboard to full duplex, the port stops speaking the auto-negotiation protocol - so if the router port is auto-negotiating, it will drop to half duplex. Try setting both the router and the mobo the same. If there is no option to set the router port, then put the mobo at half duplex and see if that helps.
at the moment i only have 1 computer and 1 laptop on the network and the laptop seems to getting the proper speeds. my boss sold me the 680i so it's a replacement on an old machine that i had but other than the mobo everything else is the same. first i had it on auto-negotiate then changed it to full duplex and that didn't help but i was too dumb to even consider half-duplex so i changed it to that. it appears to be working right now but i'll give it a couple of hours or so and see if the speed drops again. thanks.
i'm getting the slow downloads again. could the bios have messed up anything? i currently have p32 on it right now.
It's probably your network, not the board. I had all kinds of problems with my router, replaced it, no more network problems. This goes double if it's P2P stuff you're having trouble with.
Running Vista and you weren't before maybe? uTorrent user, maybe? Try a different client. The last few versions of uTorrent have been network killers for me... which is a shame because I liked it a lot up until now.
haha no vista is never touching this machine. i'm just referring to downloads in general like if i wanted to download adobe acrobat reader the speed would be slow.
