AmongTheChosenX
- Sep 24, 2007
I can sufficiently say that I have tried updating the bios. But some bios work better than others. So, depending on ur system, an older bios may work better at overclocking than newer bios. But currently, I (the friend with the 650i), have the latest bios. Plus he is talking about stock voltage. You have prob. messed with voltages, and thus bought an aftermarket cooler, and ur sig. confirms it. You can def. get the same output ur getting right now on an 680i or even an P35 board. But if you are looking to overclock ur processor more than 3.0GHz, good luck with that since you're pretty much at the wall with that processor and pushing it even more will degrade the processor. If you want faster speeds, get a better processor. I'm not tryin flame you or anything but i dont see the need for a 680i when you already have a good enough Asus P35 chipset motherboard that will easily spank the 680i chipset. Also to mention, that Anandtech article was written November 8th, 2006 and the P35 chipset was released in June of 07'. But, as an honest answer to your first post, I would spend a little extra and get a P35.
ok, AGAIN, SOMEONE GAVE ME A 680i! AT THEIR EXPENSE!
and my P5K-E has DIED ON ME TWICE, and I'M NOT USING THAT PIECE OF CRAP AGAIN.
and i want to try something different.
yes i messed ith voltages... to get to 3.2.
my new board was so crappy that it wouldnt even apply any voltage. so i was stuck at the stock 1.325 Vcore. that was able to run to 3.0 ghz on my E2180.
and that is NOT the limit. this processor an do 3.33 at 1.48 ish Vcore.
under water could go to 3.5 easily.
my "aftermarket cooler" was purchased when I bought all my other parts. I NEVER used the stock cooling its way too insufficient.
