680i CPU voltage -- very erratic!
S-B
Well, I've got a strange problem with my 680i LT SLI (flashed with standard 680i BIOS). Before I get my E8400, I wanted to see how far I could push my system with my lapped E6600.
My vdroop is about ~0.05V. I have the vcore set to ~1.5125, so that gives me about 1.45V (that's what the BIOS tells me). However, OCCT reports 1.42V at idle, but a whopping 1.62V at load. That puts me at 66°C, and I've only put the clock to 2553MHz! I'm afraid to pop up the multi to go over 3GHz, because this thing will burn up.
Is this normal, or even safe on air? I'm running a Scythe Ninja rev.A, so I'm around the top-end of air coolers.
Edit: For reference, here's what I'm running right now:
e6600: 2553 MHz (6x 425.5 MHz), 1.45V
DDR2: 851 MHz 4-3-4-10-2T-3-15-5-10, 2.125V
680i LT SLI: vFSB 1.4V, vSPP 1.45, vMCP 1.55v
At the voltages you are running at I would not trust any software and measure with a DVM (o-scope even better but thats asking a lot :D )
Vcore Readout is at every solid state capacitor around the CPU socket ( the + contact).
You might find this interesting/useful but I do not recommend doing hard volt mods when running near Intels Absolute Max Vcc. unless you dont mind buying another CPU.
http://www.xtremesystems.org/forums/showthread.php?t=154897
Alrighty, thanks for the advice Bill. I'll see if I can find my DVM in one of these boxes...
