Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
get riva tuner and make sure all the pipelines are turned on. I know this should be done already with a GT but those look like the scores i got with my plain old 6800.
I don't use profiles meself, so could just be speculating, but you aren't accidently using an nVidia profile with these benchmark programs are you? A profile with aa turned on or something?
did you remember to install your nforce 3 drivers, I forgot to one time after installing windows and thats about where my scores sat if I remember right,
also how far did you over clock your card? when I pushed mine to far it would start to loose points in 3dmark
