$600ish WoW Build.
freakycody
BUILD PUT ON PAUSE.
See Posts 2 and 3.
I will start a new thread at a later time. Thanks.
Looking at building a nice new PC, mainly to play WoW, want to keep it fairly affordable.
NOTE, I know new cards are coming out from AMD. Should I hold out for a few weeks before even considering a build till the new cards come out? If so that is prefectly fine for me.
Gaming (WoW) / Web Browsing / Media Center (watching a few movies on the big screen)
~$600-700 (the cheaper the better)
3) Where do you live?
Washington, not close to a microcenter
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
CPU, Ram, Mobo, PSU, HD, Graphics card, case, OS, Dvd burner.
Got 420watt Enermax Noisetaker But I take it won't be adequate for this build
6) Will you be overclocking?
No
1080p 52" TV, and a 19" 1440x900 lcd. Shooting for using the TV.
Whenever I can get the best deal on parts. Next few weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Maybe USB 3.0 would be nice jsut for new devices down the road.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
I have an XP prof license... but probably should upgrade to 7.
Hold out for a few weeks for those new cards. They may not be good buys initially but they may force price drops on other video cards.
And yes, you're looking at a new PSU.
Your the man. Figured you would chime in. To others, disregard this thread. I will post up a new one come the release of the new cards.
