--Primarily Gaming (FPS/WoW), but also Web and Graphic design (mostly photoshop but i dabble in some light 3d work).
--Shooting for a ballpark of $600, not including tax and shipping (I can WillCall at Mwave for $5)
3) Where do you live?
--Los Angeles County, California
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
--Mobo, Cpu, Ram, Gpu.. I think
--Case (not sure on model, generic ATX), Antec Basiq 500w PSU, A couple SATA Hdds,
6) Will you be overclocking?
--No
--I have a 17in (1280x1024) in my pc room, but I do occasionally move things to the 40in (1920x1080) tv in the entertainment room.
--There is a computer fair March 20th that Ill be visiting, depending on the prices Ill buy there, otherwise the end of March.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
--Nothing that I can think of.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
--I do, Windows Vista Home 32bit.
So basically as you can derive from all of the above, I have'nt built a PC in quiet some time. The last piece of hardware I bought was a Radeon x850 and that was some 4+ years ago. Id like something that should hold up for a resonable length of time (although I know the computing world can change rapidly). Please advise of any trade-offs that make sense or pieces that need upgraded in the following proposed build:
Mobo: $125
ASUS P7P55D LE
http://www.mwave.com/mwave/SKUView.asp?scriteria=AA76406
CPU: $200
Intel i5-750
http://www.mwave.com/mwave/SKUView.asp?scriteria=AA76366
MEMORY: $110
Kingston 2x2gb ddr3 1333
http://www.mwave.com/mwave/SKUView.asp?scriteria=BA25731
VIDEO: $180
Sapphire Radeon HD 5770 (Juniper XT)
http://www.mwave.com/mwave/SKUView.asp?scriteria=BD11194
PSU: $0 (Reuse)
Antec Basiq Power 500W (BP500U)
http://www.mwave.com/mwave/SKUView.asp?scriteria=BA31526
--No
Mobo: $125
ASUS P7P55D LE
CPU: $200
Intel i5-750
MEMORY: $110
VIDEO: $180
PSU: $0 (Reuse)
