Hello there, long time lurker here, finally registered. )
Mainly playing Bad Company 2 & Starcraft 2
$600 w/o tax or shipping
3) Where do you live?
NJ, 30mins from Microcenter
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, RAM, Case, Video Card, Motherboard, PSU, dvd drive, and HD
monitor, mouse/keyboard/speakers
6) Will you be overclocking?
Possibly
22' 1920x1080
Placing order in a week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
sli would be a plus but no biggie
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, windows 64bit
So far the following is what I was thinking of getting:
newegg shopping cart pic
$39.99 - Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
$229.99 - GIGABYTE GV-N460OC-1GI GeForce GTX 460 (Fermi) 1GB 256-bit
$94.99 - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
$79.99 - ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard
$76.99 - AMD Athlon II X3 440 Rana 3.0GHz 3 x 512KB L2 Cache Socket AM3
$59.99 - Rosewill Green Series RG630-S12 630W
$59.99 - SAMSUNG Spinpoint F3 HD103SJ 1TB
= $599.93 w/ combo deals and w/o tax
I was wondering as well if the x3 440 was a good to overclock using the stock fan or would I need a better fan/heatsink? Or instead of the x3 400, I was thinking of getting one these combo deals from microcenter.
Thanks for your time and help.
Possibly
22' 1920x1080
Yes, windows 64bit
