$600 Budget Build - Please Review
dibbs
This is my first build. Please review it and try to keep it around $625-$650 if u want to change anything.
The Build:
Case: Cooler Master Centurion [link]
Power Supply: Thermaltake TR2 W0070RUC [link]
Motherboard: Gigabyte GA-P35-DS3L [link]
Processor: Intel Core 2 Duo E4500 Allendale [link]
Memory: G.Skill 2GB DDR2 800 [link]
Hard Drive: Seagate Barracuda 250GB SATA [link]
Video Card: XFX GeForce 8600GT 256MB GDDR3 [link]
Those are the main components. The keyboard + mouse + DVD Drive + small toolkit coupled with the main components comes to a grand total is $599.90 before shipping. If there are any components you think would better suit this system please let me know.
Thanks in advance!
I have had some iffy experiences with Tt psu's, but others have had better luck. In a system like this which is obviously intended for mere office work, it would probably work fine but personally I'd never put a low end psu in *any* system I build. There are several posts scattered around here about Tt psu's
Yeah, I was unsure about wattage and psu's. I basically just went with the top-rated psu for a specified price range on newegg.
This is a better PSU:
$50 - XClio 500W Goodpower PSU
The Stablepowers are also good (rebadged Enhance units). There was a coolermaster unit that was $9 AR, but I'm not sure if that deal is still going.
