600-1000$ gaming build
Jospeh
Thoughts: considering building cheaply and upgrading the CPU sooner rather than later.
Other thoughts: I'm going to probably get another monitor (not included in build, cheap TN panel for sure). Considering getting a 3rd just to try out eyefinity...just a thought though.
1) What will you be doing with this PC? Gaming?
Gaming and a little bit of everything. A CPU good enough for gaming should be good enough for everything else.
600-1000$ 1000$ is kind of the upper limit. I'd like to spend less where it makes sense to spend less.
3) Where do you live?
Near a microcenter.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU
Motherboard
Ram
Video Card (see note below)
Boot/software install drive (Already have storage drives)
Case
PSU
5) If reusing any parts, what parts will you be reusing?
monitor
mouse
mousepad
keyboard
Possible to reuse a 4870 but I think I want to upgrade it..
6) Will you be overclocking?
yep
1900x1200 monitor with display port.
By the end of this month I need to have it. I'll be getting parts til I can build it.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Not really. Onboard RAID for RAID 1...maybe? No real plans for a hardcore RAID setup so this feature can be ignored.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, Windows 7 64bit.
$190 - Phenom™ II X4 965 Black Edition + 785G-E53 AM3 ATX Bundle from Microcenter
$98 - G.Skill Ripjaw Series F3-12800CL9D-4GBRL 2 x 2GB DDR3 1600 RAM
$290 - XFX HD-585X-ZNFC Radeon HD 5850 1GB PCI-E Video Card
$56 - Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$100 - XFX P1-650X-CAG9 650W Modular PSU
Total: $735 plus tax and shipping.
Should be enough for 1920x1200.
Choose your own case:
$70 - Cooler Master RC-590-KKN1-GP ATX Case
$80 - Cooler Master RC-690-KKN1-GP ATX Case
$70 - Cooler Master CM690 II ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Lian Li Lancool PC-K7B ATX Case
$90 - Cooler Master HAF 922M RC-922M-KKN1-GP ATX Case
$110 - Lian Li PC-E8B ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$120 - Thermaltake ElementS VK60001N2Z ATX Case
$130 - Cooler Master Storm Sniper ATX Case
$150 - Antec P183 ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$170 - Cooler Master Cosmos S 1000 RC-1100-KSN1-GP Full Tower ATX Case
$180 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$180 - Lian Li PC-B25F ATX Case
$210 - Silverstone FT01-B ATX Case
$220 - Lian Li PC-A71F Black ATX Case
$240 - Lian Li PC-V1200A Plus II ATX Case
$300 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
$330 - Silverstone Temjin SST-TJ07B Full Tower ATX Case
Total: $635 plus tax and shipping.
Should be enough for 1920x1200. <case snip>
That's missing a PSU :(
Couple questions.
1. Going i7 is going to add how much to the total cost? around 200$? I don't think I will go i7 but I'm just considering the option should I decide for a beefier CPU.
2. is the GTX460 viable or should I just got with the 5850?
Going Core i7 would cost you at least $200 more, especially if you bought the processor, motherboard, and memory from Micro Center:
$200 - Core i7 930
$220 - Gigabyte GA-X58A-UD3R
$170 - Corsair XMS3 3x2GB DDR3 1600 (assuming you can find it in stock)
Yeah, I guess just like I thought. Could I get a double check if that WD Blue a good choice? I've heard good things about samsung drives lately. I just need something fast for the most part.
The WD5000AAKS (aka the Caviar Blue) and the Samsung F3 drives are good choices as they all use 500GB drive platters.
