ProfessorKaos64
- Sep 18, 2009
http://www.techspot.com/news/38046-AMDs-sixcore-Thuban-CPU-to-launch-April-26.html
More cores doesn't necessarily mean more speed right? Doing stuff faster? How, I sure hope most are aware how little software is mutl threaded unless you hit a professional level of multimedia design/programming/rendering etc. Having 6 cores at 2.5 ghz isnt going to blow your mind when you already have 4 doing the same. Hell, I could barely tell the diff between my 3.00 ghz core 2 quad over my 2.5 ghz core 2 before it. yes there are some exceptions, but for the most part its a damn pissing contest, and I hope most get that. Yes, true that architecture has been upgraded on both, and in the Intel field we see vast improvements on bus path speeds with QPI etc, but is it laods faster than a good ol fast Core 2, or Core 2 Quad? I'm sorry, but 6 cores doesn't make your porn load faster. When the time comes that I NEED 6 cores, and the software IS* there to use them, then I will agree whole heartedly. Faster does not necessarily mean more cores, clock speed per core is pretty much flat lining unless you over clock, and until we reach the "holy grail" of optic computing, then I don't see it going much higher.Until then its consumer hype and "who's got the bigger wang" argument.
What I want to know from [H] readers, is with speed at a fair constant, and just more core's piling up with some architecture improvements, is a 6 core system going to wow you over a 4 core or fast 2 core when theres not much to take advantage of it?
