5U 24bay Chassis Backplane cable
postalis
Hello there,
today my new 5U Chassis arrived.
Now i am one step closer to my new Storageserver.
I unboxed the chassis and now i am confused about the cable on the pictures attached.
Can someone telle me, what function they have and where to connect.
The cables are connected to the backplane (red circle):confused:
Could be Sideband cables for enclosure management so that the controller can control the drive LEDs (access, identification, error reporting)?
Maybe,
there are 12 pcs of this cables, 2 for each backplane "etage" (which itself holds 4 drives).
But where to connect? i have a HP expander, but no pins for this cables ^^
It is probably sideband cables for error and activity LED usage in non SES-compliant cards.
I bet:
those 6 (4 pins) connectors are sgpio(the current trend says "sideband")
I believe, your backplate is not SFF-8087 and supports only SES (not SES2)
to use those connectors, you need to find the server vendor and search manual PDF for backplate
I bet:
It could be SGPIO or I2C, they are both 4 wire connections.
I already searched for the manual, but the vendors website doesnt even list the chassis...
maybe someone else has a little more luck, my chassis part no is RMC5E2-QI-XPSS-ML
Right, it doesnt have SFF8087 connectors, it has SFF8470.
Well, this link actually does not work (just for me?), i found it also, but doesnt give me any target^^
"The web site you are accessing has experienced an unexpected error.
Please contact the website administrator. "
Yeah, that was also the first thing i did, but as i already mentioned, i cant find the product on aicipc's website, do you? ;)
a photo of the front and back of the unit might speed this process up if you want help
Then there is a problem with the AIC website, that is the product page.
It really seems to be those I2C Connector-Cables.
Now the Next step is, how do i use them, do i need to use them?
As far as i see, they are for the HDD-LEDs, arent they controlled over the SAS-Cable?
Some Pictures i took today:
Guess you need one of these?
Read the PDF I linked to
Does not look like LEDs connectors.
if you look futrher on Stanza PDF, there are 5 cables on each connector for LEDs( 1 ground, and 4 actives for LEDs)
I have AIC case with Simple/dummy SATA backplane
http://www.aicipc.ru/data/files/files/90_file.pdf .
the easy way is take a screenshot front and back of your backplane board/pcb
or you can trace the connector on the board/pcb and find out IC/Chips that links to the connector.
the link that I provided on my previous post, you can see the backplane configuration as follows:
SS2 Serial ATA(SATA) 3G
SC3 Parallel SCSI U320
SA1C SAS 3.0 (CPLD with SGPIO) <--- looks like your server case
I took some pics from the Backplane, sorry for the bad quality, im not a professional^^
As u see there are a bunch of capacitors and resistors as well as 4 ICs saying "4953GM/540044" (google says, this are mosfets) and one IC "51CNYKK/7407" (Google: TTL hex buffers/drivers)
Uploaded with ImageShack.us
