something isn't right there, I run it at 2560x1600 with 4x AA and HBAO off, and I get around 70-80fps average.
at 2560x1600 2xaa I get 90ish fps average.
40 seems way too low.
Just did a run @ 2xaa on a 32man server
Frames, Time (ms), Min, Max, Avg
87853, 1066772, 4, 175, 82.354
What's the rest of your system like? This is the specs of the machine xbit tested BC2 on.
Don't throw your money away unless you have wayyyy to much of it
Why would you wanna run a 5970 @ 1680x1050? 5870 should be enough
i7 920 @ 3.2ghz
12GB DDR3 600
P6X58D
Win 7 x64
I'll do another run with HBAO one, but from what I remember it really didn't drop it much
anyway, a 5970 for 1680x1050 is way overkill, if you can't go higher, get a 5870 or wait for fermi. Don't throw your money away unless you have wayyyy to much of it
who would want to game with dual monitors?hey, it may be over kill now
but i would upgrade to dual monitors later with the 5970
that would be awesome
for gaming it would make no sense because the bezel would be right in the middle with 2 monitors.people that cant afford 3
Yeah doesn't seem quite right, although we're running with HBAO off which is a massive FPS killer and seems to make little visible difference, they're probably running with that on?.
