Originally posted by smcgee85
What do u guys think of the 5950 ultra?
Is it any good?
How does it compare to ati equivalents?
Which mod do u think is the best one?(albatron, asus, etc)
WOW
no affence man but u need a life u have 10000 posts
uh dude with the 5900 moded
Brent stop laughing at visible assasin u got 8000 urself
hey uh visible assasin did he get a bugged card or somthin the guy with the fuzzy text
here is the post i actually want a reply to
ok i can wait a month or two i probably would off anyway cus im getting a new comp too and money doesnt grow on trees
what am i waiting on?
i mean what new cards are comin out
are they on the nvidia or ati site?
and the 9800XT looks like the better bet...ABIT IC7-G (i875P), Intel Pentium 4 3GHz C, 2 X 512MB Corsair XMS PC3200LL TwinX Dual Channel DDR400, Maxtor 40GB ATA/133, Windows XP Professional SP1 with DirectX 9.0b.
ABIT 9800XT Operating at default clock speeds 412/730 using Catalyst 4.2 (WHQL).
GeForceFX 5950Ultra Operating at default clock speeds 475/950 using Forceware 56.56 (WHQL).
Originally posted by LiquidX
smcgee85 it does not make sence nor would I advice you to buy a 5950 so late in the game. A month or so ago I would have said go ahead "you cant wait for ever", but new cards are right on the horizon (a month or 2 away) and that $400 or so dollars they cost would be better served getting one of those new cards.
Right now there two cards if you if you need a card you should consider.
1-A 5900 from Nvida
-or-
2-A 9800 PRO from ATI
I would go with with the 9800 Pro from ATI or wait.
Originally posted by Balderdash
A compaq? You're going to let Compaq build your AMD64 system?
Okay, I'll help you out, but this isn't going to be easy... The Compaq version of the AMD64 3400 is in their 8000 series computers, the mobo in it is a compaq made nForce3 150 .... and I think they actually offer their own 5950U - you might want to check into it, it might be cheaper from them if they are building your system...
*goes to wash my hands - I feel dirty now -
I then cry hard and horrible on my pillow for the poor 3400 that was sent to a compaq factory after it's birth*
LOL
ok heres the specs of the comp im looking at and im 99% sure im guna get
AMD 64 3400+
er not sure bout the motherboard the compaq site doesnt say but ill find out
1gb of PC3200 ram
160 gb 7200rpm HD
uh it doesnt matter but it comes with a 9200se (which i will replace with a better card)
anything else of importance?
