I'm going to snag a 5930k from the Intel Retail Edge Holiday deal and do a new build. Looking for a bit of advice.
Gaming
$1750 total. Less is better. I don't like going top of the line on graphics cards. I prefer the next step down and then adding a second card later or just upgrading.
US - Ohio
Mobo/Ram/Cooler/PSU/Graphics Card/Hard drive
Not reusing but I already know I'm getting a 5930k for ~$225. I'm also getting a Corsair Carbide Air 540 case because I like it ($120).
6) Will you be overclocking?
Yes
1440p eventually
December 2014
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Crossfire/SLI eventually but single GPU to start. Built in WiFi would be great if that's a thing.
No
So after the processor and case, I have about $1400. I'm thinking of grabbing the MSI X99S SLI Plus mobo with crucial ballistix sport 16gb ddr4 2400 combo on Newegg right now for $377. I also would like to try something like the Corsair h100i for a cpu cooler being that i should have plenty of room in the Air 540 case. Thoughts? Suggestions? I haven't built since 2011 so I'm kind of out of the loop.
Gaming
US - Ohio
Yes
1440p eventually
December 2014
No
