maliclipse
- Oct 19, 2007
If you were looking for a brand new 5870, would you look for a reference board or would you look for a rev2?
I have a pair of Gigabyte rev2 (ultra durable edition) 5870s in CFX and noticed that one runs 20-30 degrees higher than the other because they're next to each other on the mobo. Even though both gigabyte cards have two fans on them each the problem is that the fans don't blow the heat out the case so even with a 120mm case fan blowing right on the cards one card overheats because it doesn't suck air in and out the back.
I'm thinking a pair of reference boards spaced out by one slot would be a better solution because they'd be able to suck cool air in and out better.
Thoughts?
Thoughts?
