5870 cooling mod thread
NeonGuy
I removed the back plate since i thought it was keeping heat in. my temps in furmark are lower but i would somebody to confirm this please..
test fur mark for 500 secs and then take off the black backplate and test again recording your temps please.
report back your findings !! 4c diff
backplate off :
afterburner/amdgpuclock
1000mhz 1.274v
1300
500 seconds of furmark test 67c load. 152f
back plate on : testing
1000mhz 1.274v
1300
500 seconds of furmark test 71c load. 159f
Randy
My 5870 overclocked to 900/1300 never exceds 68-70 under full load, and my fan is set to 28 in CAT drivers. Granted i have better air flow than the next guy. I have a few 120mm fans that i drilled holes in my side panel blowing directly over the processor and graphics card. All fans are hooked up to a fan controller and set to lowest speed. I HATE noisy comps. I pride myself by having the quietest comp i can possable build. The loudest hardware are my hard drives....untill i buy a few solid state in another moth or so.
afterburner wont oc more than ccc 900/1300
i can set volts and fan speeds..
it has to settings in the bios on my card..
