theactioncombo
- Apr 12, 2008
Both can be had for about the same price. Which is going to give better performance at 1920x1080?
5850 hands down. the 5770's are bogus. 5850 for future proofing and expecially if you add another 5850
Why exactly are 5770s bogus and not as future proof? The CF price/performance scaling is probably the best you can get at the moment.
It's really only worth it to SLI/Crossfire 2 top end cards.
The price of two compared to a 5850, is not that great, especially since a single 5850 has space for another GPU (if you have a xfire capable mobo).
Something like 160 x2 is 320usd for 5770 xfire, and it's 310-360 for a single 5850.... not to mention the xfire mobo.
Also, does anybody remember the 8500gt SLI setups? Had 'em just for the SLI name![]()
Im waiting for 5850 price drops for crossfire.
When will that be?
Chances are by the time the prices get good there will be a new improved card from ATI or NVIDIA.
Ahh, seems there is a lot of inappropriate dislike for the 5770s on this forum as well...seems to be a common theme.
At a 1920x1080 resolution two 5770s in CF will perform closer to a 5870 and depending on how you OC it, will outperform the 5870 in some applications.
The only downside to this, of which has been stated is that there really isn't any upgrade room. However, depending on when your next upgrades are the 5770s in CF can last you awhile.
I believe a pair of 5770s are right now the best bang for the buck if you're able to do it. About the same price as a 5850 with the performance of a 5870 that scales extremely well when OC'd.
Although you would be happier with the 5770x2 for a few months, in the end there is not a good reason to go with a 5850 now.
