sabregen
- Jun 6, 2005
I just opened the msi link at the top of the thread. click the link, then click the "Download" link just above the file image, on the left.
well this is what I have done 950core 1125 mem vs stock
l4d maxed out 1920 x 1200 8xaa 16xaf. I ran furmark @ 1280 x 1024 no aa windowed
I am pretty sure you can tell which is which w/o me labeling them.
and furmark is the only other thing I really have that would give a consistent reading.
Dang that's a ridiculous frame bump. I'm impressed especially with the bump in the "minimum fps" department as that's all that really matters to me. Just gotta hope you get a decent chip that can OC.
Oh and how safe is it to run these overclocks over a long period time. Could you potentially damage the card?
wait does this unlock the extra shaders or only allow you to OC higher?
I know the feeling I upgraded from a 8800GTS myself. Great card but the 5850 beats it back and forth
Regarding the clocks. Yes, these settings are a keeper. They are rock stable and I'm liking the temps as well.![]()
Enable overdrive
create a profile in CCC and save it, but do NOT activate
c:\users\<user name>\appdata\local\ati\ace\profiles [must have show hidden files on]
open the .xml with the same name as the profile created
make the following changes
Feature name="CoreClockTarget_0"
Property name="Want_0" value="40000" [previous should be "15700"]
Feature name="MemoryClockTarget_0"
Property name="Want_0" value="90000" [previous should be "30000"]
Save and close file
now by going in CCC and activating the profile the idle speeds should be 400 and 900 instead of 157 and 300
this will marginally increase idle temps
Hey nice work Diesel, is that with the stock cooler as well?
Holy! This thread still alive?
Yes sir, stock cooler![]()
So is the Asus bios unlocking CCC Overdrive to 900Mhz territory? I didn't know that CCC could be unlocked that high. I have a Diamond 5850 and can only set 775Mhz with their biosI don't want to really raise the vCore right now but I know I can get over 775Mhz with stock voltage and would love to be able to use CCC to do it so I can keep the power savings too.
Good evening my model is a his 5850 iscooler I don't know if it is a model of reference
