So im going to be setting up a NAS. I'll probably be doing harware RAID 5 but havnt decided on FreeNAS or just using something like WHS or Windows Server 2008 (since i want to use it for file storage but maybe printer sharing later down the road).
Anyway... the WD Green drives (WD20EARX) 2TB 6GB/s drives just dropped to $114.99 on NewEgg so i was thinking of using 5 of those... but they are only 5400 RPM.
Is that a big issue regarding speed? Yes they are not the high end RE4 drives but hey lets face it, for my home use i don't need the crazy nicer drives... but should i go for the 5400RPM? Will the speed be much slower then say 7200 RPM?? Right now all my media for my HTPC Is stored on local HD's, some of them are green drives (forget which ones).... but im going to be moving everything to the network, worried about speed. SUre its a gigabit network but still, speed is a concern as all my stuff are x264 blu-ray rips (about 12GB each) I want to make sure i can still stream them (i mean i can stream it from my HTPC to my main office pc without problems and right now in on 100 meg since i have an issue with my network cable
