Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
That would have been a more helpful link except that as soon as I posted the thread I got the 502 error on my own thread. Had to find your reply on my blackberry.
Dunno if you got this far, but this is from our FAQ up top.....
(16) I'm having problems with the forums (502 Bad Gateway) (various problems). Do what we call the drill. Clear you cookies (log out of the [H]), clear your browser cache and cookies, flush your DNS cache and log back on. If the problem isn't gone after that, post your problem on the forum and we'll see what can be done. If you follow the steps outlined, it will save you and us loads of time.
Ya, but it only happens randomly on random tab i open up...
havent tried it on FF but may have to.
I thought perhaps [H] put in conneciton limits for IP's so when you try to open say 10+ tabs, it wont load some cause it hit your limit, as once i hit F5 it loads fine.
@ home on a 4mb / 768kb cable line from Amnet
@ work on a 4mb /1mb cable line from Amnet
@ work on a 1.5/1.5 fiber connection via Racsa
but Amnet basically gets its lines from Racsa.
So far it hasnt happened while using FF 3 on my Asus EEE and i had about 13 tabs open a few minutes ago, when it does happen it has been on IE8 under Windows 7 RC 7100.
