$500 to spend
Mangudai
Looking to go used this time around
1) What will you be doing with this PC?
Gaming,Watching movies/music, and PhotoShop here and there
$500 but this is a bit flexible
South Florida(no microcenters unfortunately )
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word"Everything" is not a valid answer. Please list out all the parts you'llneed.
CPU/HSF/Mobo/RAM/OS
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply.List make and model.
ATI 5850, Corsair TX750, PCI x-fi(not sure if I could squeeze an PCI-e asus xonar in the budget)
6) Will you be overclocking?
Yes.
7) What is the max resolution ofyour monitor?
1680x1050(going 1920x1080/1200 later this year)
What size is it?
22"
Within 4-5 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc. 10)
Crossfire/SLI support, USB 3
Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit?
No I'll have to purchase an OS.
So you realistically have a budget for $400 for the CPU, mobo, RAM and HSF and you want to OC?
The OS is gonna cost you $100 no matter what.
Yes sir and I know. Most likely I'll purchase a used i7 920/Mobo combo for $200-$220. OS for $100. RAM for $50-$75. Haven't decided on a HSF yet(212+?).
My wireless adapter and sound card are PCI. Trying to ditch at least one of them so worrying about legacy support isn't too much of a concern
The RAM should not cost more than $50 unless it's a 16GB set. The 212+ is fine.
