$500 Office PC build
yangx
little gaming if any, casual games. Mostly web browsing / Office work
520 tax/shipping included
3) Where do you live?
Minnesota
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, RAM, Case, power supply, motherboard, hard drive, cd/dvd burner, and a video card - on board video card is fine.
I have no parts to reuse.
6) Will you be overclocking? no
19inch - 22inch
building or buying - which ever is best
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
none
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, I have a 32/64bit windows 7
I'm building this computer mainly for Office work.
I've put together an Intel build.
LIAN LI PC-A05NB $89.99
GIGABYTE GA-EP43T-UD3L LGA 775 Intel P43 ATX Intel Motherboard $79.99
SAPPHIRE 100291L Radeon HD 5450 $44.99
CORSAIR CMPSU-450VX $64.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 $91.99
Seagate Barracuda 7200.12 ST3500418AS 500GB $54.99
Pentium Dual-Core E5400 $69.99
and a dvd burner for 20$
Total about $516.93,
I'm looking to order something soon and build it by the end of the week.
Also, any recommendation on an AMD build that would be better for the $$.
I'm also interested in a i3/i5 build if I can keep it under $600.
added cpu
Honestly, just get a Dell. For your uses it makes the most sense.
I configured a Vostro 230 that has a Core 2 Duo, 2GB RAM, 3 year warranty, and a 20" monitor for $550. Look at the Vostro's instead of the Inspirons and you can get a good deal.
Also I think you forgot a CPU in your list...
hmm that's not a bad idea. I'll look into that.
If the prebuilt route doesn't pan out, that custom build is not that good for the money. Mostly good parts but shitty price to performance ratio.
Better setup for the money:
$163 - AMD Athlon X4 635 CPU + MSI 880GM-E43 AMD 880G ATX Motherboard
$82 - G.Skill F3-10600CL9D-4GBNT 2 x 2GB DDR3 1333 RAM
$55 - Samsung Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
$57 - Antec NEO ECO 520C 520W PSU
$90 - Lian Li A05 case
$20 - DVD Burner
Total: $467 plus tax and shipping.
Faster hard drive, faster CPU, better CPU for multi-tasking, large, cheaper but equal quality PSU, and cheaper yet equally performing DDR3 RAM.
